I've made up my mind going to build a 395 stroker Bore size will be 3.905 stroke will be 4.125 my head package will be the AFR 225 or the trick flow 225 guess im askin if some one will spec a cam for me and what kind of power should i expect? Would like to make some where around 500 to the tires also would like to use some pressure later on but will run na for a yr or so keep in mind this will be in a 5.3 block yes i know it would be better to use an LQ4 or LQ9 block but i wanna say hey look its just a 5.3 i guess im asking you guys if this would be a decent combo to run on nitrous for a while then switch to a tvs2300 or a turbo
Thanks in advance
