Results 1 to 10 of 11
Thread: 243 vs 01 ls6 heads
    Feb 2009
    Okeechobee,Fl
    243 vs 01 ls6 heads
    Which heads would be better for a modified 5.3 or turbo 5.3
    Robby-2003 Regularcab stepside, 5.3, 93 Nelson tune, 3.73 and Grenade 80, 2/4 drop, 22's LQ4 and 4l80 in garage waiting to be installed!!
    1967 Chevy pick-up, torch red, LS6 454 w/mods, 4/5 drop, 18inch Boyd
    Pittsburgh, PA
    well the LS6 heads have hte lighter and longer valves. other forms of the 243 have standard valves
    both flow same
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Feb 2009
    Okeechobee,Fl
    Thanks , I thought they were similar.
    For turbo unmilled 243s would work awsome because of the larger combustion chamber. For N/A though, you would lose power.
    Oct 2008
    Houston
    both flow same
    Only the 02's have the lighter valves.
    01 LS6 heads had regular 243 valves with weaker "Blue" springs.
    02 got the light valves and yellow springs and LS2 243's got the
    yellow springs too.
    2002 Tahoe 4.8 - soon to be turbo'd - SOLD
    1989 Mustang - LX Vert - 351W-TT - 2inches of dust covering it
    2012 Raptor - 497rwhp at 10psi
    If you aint breaking - you aint going fast enough
    Pittsburgh, PA
    Quote Originally Posted by r.barn View Post
    yellow springs too.
    dont forget the 03 04 LS6 motors as well run same as the 02s
    412 Motorsports
    Feb 2009
    mississippi
    na the ls6 milled down a hair did grate for me but if your goin turbo get an ls2 head and have it p&p for the most volume you can get
    04 1500 5.3L custom hp tuners tune by myself don have a pic of it yet so hear is my old 01 chevy 5.3 460hp 13.669 @ 116
    you can run ls2 heads on a small bore 5.3?
    Feb 2008
    St Louis, MO
    You will lose a lot of compression if you put the 6.0 heads on a 5.3 because of the bore difference.
    <>< Nick <><
    More Pics of the Z28's:
    http://www.omnipotent-goku.com/iroc/gallery/album140
    Pittsburgh, PA
    all the 243s mentioned have 64.5cc chambers
    if you install these on a 4.8/5.3 your CR would be 9.1
    412 Motorsports
