Allen! Have you considered CNG?
I have been looking at the benefits of running CNG (Compressed Natural Gas) or propane in my truck. The closest dealer i have found that can install a kit is in Austin but the problem is you have to use his computer and timing. Have you thought about putting a kit together and putting it on these trucks? The parts are not the expensive part that the guy sells it is his labor and tuning.
Propane has an octane rating of 110-120.
Natural gas has never cost more then gasoline.
If you were able to put a kit together i would be all over this.
2004 EXC Silverado 6.2L
Mods:
6.2L L92, Ported and Polished stage 3 heads, 95mm Throttle Body, 100mm MAF, NA, Pacesetter LT Headers, Magnaflow X-Pipe Muffler, Electric Fans, 160* thermostat, 2" Drop Shackles, Hellwig Sway Bars Front and Rear, Monroe Reflex Shocks, NGK Spark Plugs, AMW Oil Catch Can, 17"x10" wheels on Kuhmo Tires.
