Results 1 to 10 of 14
Thread: dropping cross member
    Oct 2008
    Shawnee, Ok
    if i take out the cross member so i can drop the oil pan to replace the oil pan gasket well it affect the front allignment??
    02 chevy 1500 ecsb. 02 lq4 6.0, nelson tuned.(sold but still in the family)
    89 chevy 1500 rcsb -under construction-
    Jul 2006
    College Station, TX
    It should not cause any kind of problem.
    2004 EXC Silverado 6.2L
    Mods:
    6.2L L92, Ported and Polished stage 3 heads, 95mm Throttle Body, 100mm MAF, NA, Pacesetter LT Headers, Magnaflow X-Pipe Muffler, Electric Fans, 160* thermostat, 2" Drop Shackles, Hellwig Sway Bars Front and Rear, Monroe Reflex Shocks, NGK Spark Plugs, AMW Oil Catch Can, 17"x10" wheels on Kuhmo Tires.
    Round Rock, TX
    no alignment issues at all
    Oct 2008
    Shawnee, Ok
    is there anything else i'll have to remove before i can drop the oil pan?
    yea shawns number from your phone hahahahahah
    really that should be it, maybe a few little things.
    Oct 2008
    Shawnee, Ok
    lol. so it shouldnt be to hard then?
    Wasilla, AK
    Starter, front driveline, front diff, should be wide open after that.
    2001 ECSB 4x4, 5.3, Radix, 3.0 pulley, VHP Trucker cam, 216/224 .551/.551 115 lsa, 1.8 Crane roller rockers, 4L65E, Yank SC3000, 3.73, Cal-Tracs, HPTuners.
    If it's 2WD the pan removes itself pretty much. If 4WD the axle needs to come out or at least be mostly removed....
    Oct 2008
    Shawnee, Ok
    its 2wd
    It's less of a crossmember and more of a frame brace. No, it will not affect the alignment. If you wanna check it drive the 1:43:56 to me and I'll check it.
