Results 1 to 10 of 17
Thread: NGK tr55. Does this sound right.
    Corbin,Ky
    Gonna do plugs and wires in the next couple days and every thing i've read about these trucks seems people like these plugs. At least on the forums i get on. I went to advanced and picked up 8 tr55's and the guy there tryed to tell me they are wrong for my truck. I got em anyway. So was he just full of it? My truck is an 04 sierra 5.3 with 116,000.
    Dec 2008
    La Porte TX
    I called a friend to see what he ran, and he told me to run those plugs. he uses them on his Camero's. He has had a lot of them, works and races them..
    5.3, small cam, 918 springs, 7.4 rods, walboro pump, Full built 4l60, 2800-3000 stall, TB spacer, long tubes, cat delete, single 3" exhaust with Aero bullit muffler. Flaco tuned.
    Oct 2005
    drinking your alcohol
    i ran the tr55 for a long time... i have an 02 with the 5.3
    i dont see why they would be the wrong ones....
    unless the "right ones" were the plugs that cost 8 bucks a piece
    DamnYankee: my nana failed
    Corbin,Ky
    Quote Originally Posted by TxStVanWilder View Post
    That sounds about right. Thanks guy's. Just wanted to make sure.
    Corbin,Ky
    While i'm at it what should i gap these things at.
    Feb 2009
    Millen, GA
    gap should be pretty close out of the box but i'd still check them and readjust to .060" if necessary
    They're "wrong" because these engines may not be an application NGK spec'd when they put them out. They work good from what people tell me. I have the ACD iridium updates (ACD # 41-985) and they're the widely accepted just as good replacement. Yes, Alan may be right. They're probably $8 each retail at the dealer. No, I didn't use the ACD's because of my discount...I bought a set of eBay that were shipped from Canada for less per plug by about $0.40 than GM DEALER COST. Check them out too....
    I gap mine around .35, i have a tuned lq9
    Corbin,Ky
    The guy at advanced told me to gap em at .040 but i just wanted to make sure.
    S.A. Texas
    gaped mine at .050 on the 4.8 with cam and tune
