Results 1 to 10 of 16
Thread: Oil Level Low!!! Help
    ff_jeff Guest
    OK truck started to smoke a little a few days after the cam swap. I have been thinking its fuel. Started it up today at work, been sitting for about 2 days. Lots of smoke. I smelled like fuel, but after I let it idle for about 20 mins it was still smoking a little. I turned it off, then started it again. Low oil light came on. checked dip stick... yep... way low.
    Im thinking its been burning oil this whole time. But whats weird is I checked the oil before I went to the track and it was fine. checked it the next day after the track... fine. It still smoked, but not as much as recently.
    Yall think it might be the valve seals? Im at a loss for words right now. Looks like I have to cancel the dyno tune.
    Help please!!!
    here are the plugs
    All were fouled by oil. some were loose enough to remove by hand.
    If it's valve guide seals, you'll notice it most when there is no load on the engine. IOW, high vacuum. Try this to confirm: With someone driving behind your truck to observe, accelerate hard to about 4500 RPM in a low gear and then let off the gas pedal and coast. If you have leaking guide seals, the smoke will pretty much stop when accelerating and be the worst when coasting. This works the best if you can stay in the same gear.
    Hopefully valve seals. Did you change springs, etc. when the cam went in?
    Mar 2006
    Phoenix, AZ
    If all the plugs are like that I'm going to say that it looks like it's drinking oil through the PCV system. I can't imagine that ALL of the valve seals are bad. Pull off your throttle body and see if there is oil all over the inside of your intake manifold.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
    san marcos,tx
    hopefully that 125 shot didnt damage your rings.
    Dude its toast go ahead and buy an LSX 454 and be done with with it.
    JK I bet its drinking oil from the PCV like thunder said.
    Slimsilverado Guest
    Jeff wasnt your AFR messed up when you got your cam in? Could this have torched your rings and causing blow by?
    Southeastern Wisconsin
    jeff i know this may sound stupid but if you changed valve seals did you seat them back down? i forgot to do that, my fault, and thats what my plugs looked like when i pulled them out for that problem and it was eating about a quart of oil every 600 miles or so.
    1999 GMC Sierra SLE ECSB .... 5.3L w/ Slight Performance Tune / True Duals with Flo Pro Glass Packs.
    Project ''Bad Company'' Future = 6.0L (Forged Internals) / Boost (TVS) / 4L65E LvL 5 / AWD Conversion / Full LT's with Cats / Methanol Injection / Lowered 2" / SS Rims / Frame Up resto
    Officially Employed!!!
    Slimsilverado Guest
    Jeff also one more thing. Those gloves are gay, you look like Tyler wearing those
    ff_jeff Guest
    Quote Originally Posted by thunder550 View Post
    You were correct sir. I had about 1/2 a cup of oil inside my intake. Got another breather for the driver side, cleaned up the mess... runs good now.
    Quote Originally Posted by Slimsilverado View Post
    Hey it was about 2am and I was on shift. cant get all dirty, then get a medical call and look like a grease monkey doing CPR. Thanx for the help guys.
