i have one MCA-3004 memphis amp foresale: this is one of the if not the best highend amp i ever used and i used quite a few in my lifetime!!! this amp retails over 500.00 usd, can be found on sale for around 350.00 i'll except 225.00 for it plus shipping
Full MOSFET Design
Built-In Fully Variable High/Low Pass Crossovers
User Selectable 12dB or 18dB Per Octave Crossover Slope
RCA Bypass Output
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
4-Channel MClass Series Amplifier
Compact Aluminum Chassis with Custon Black Pearl Finish
Gold Plated RCA Connectors
Full MOSFET Design
Fully Variable Crossover: HP/LP (40 Hz - 6 kHz)
4-Way Protection Circuitry
Optional Wired Remote Gain Control
Adjustable Input Sensitivity: 250mV - 5V
Dimensions: 18.5" L x 7.6" W x 2.4" H
Number of Channels 4
RMS Power (4 ohms) 75 watts x 4 chan.
RMS Power (2 ohms) 115 watts x 4 chan.
RMS Power (1 ohm) Not Stable
Bridged RMS Power 230 watts x 2 chan.
Peak Power Output 920 watts approx.
Min. Impedance Unbridged 2 ohms
Min. Impedance Bridged 4 ohms
THD @ Rated RMS Power 0.03%
Built-in Crossover HP (40 Hz - 6 kHz), LP (40 Hz - 6 kHz)
Signal-to-Noise Ratio 92 dB
Fuse Rating 25A x 2
Memphis 16 MCA3004 Memphis 16 MCA3004 75 x 4 Class AB Full Range Amplifier
kicker CVX speakers:
10" subs 150.00 for the pair plus shipping, these cost over 135.00 each new
also a 10" sub box for 99-02 ecsb trucks
prefer pickup in houston area!!!
also have a memphis 1000D amp for the subs, dont have pic but will post it if needed!!! only 1.5 years old!!
package deal for 500.00 cash for pickup only, can or will meet in the houston area!!! if interested feel free to pm me, this is not your cheap end amps or speakers!! there well worth the dollars..any questions feel free to ask!!! the memphis 1000d looks like the one posted!!! this is some high end and very expensive audio equipment!!!
