what is a good way to break in these ls motors with a turbo
Junkyard 5.3 milled heads 200 shot, built 4l80e with circle D 4000 multi disc converter
EPS cam 23x/23x 600/603 112lsa
KP 6 link bagged with Accuair E-Level
http://www.nitrousexpress.com/
right when you turn the key on. just start revving the sh1t out of the motor. keep on revving it. after about 10min of doing that the springs should start to settle in. after the springs settle in you should be good to try and rap it up as high as you can then let off so you can hear the bov.
THAT WHISTLEE OOOOO BOY
when your done with that, take her for a spin. put it in reverse and I dunno just go about 25 mph in reverse.. now this is the tricky part. dont press the brake but just throw it into first and hammer down. great way to roast the tires and get a good smoke show going.
hope this helps!
its a fresh motor and it will be primed with oil before the initial start, he is just asking about the break in
ive got a oil priming system so i can do that without cranking it but what do i do once i start it up do i need to break in the cam and lifters or what
Roller cams and modern rings don't require the break in procedures of the old days.
Break in... whats that? lol.... mine was broke in with 19 psi at the track....lol
I did my break in at Denton on the drag strip...lol,, but Ive heard give it 1k miles or so b4 it really gets a good break in. im almost there..lol
single digit street truck
for build info
