Results 1 to 10 of 14
Thread: Need a new hood
    Apr 2003
    Wylie, TX
    I went to the body shop yesterday that I will be getting my hail damage repaired at and gave them the estimate my insurance company gave me. They took it back and checked it under uv light and said that I will need a new hood, mine is shot. He told me they use keystone for aftermarket hoods. I have heard of them and they suposedly are good hoods. I told them I want a cowel hood and asked them about Goodmark hoods. They said that I would probably have to pay the difference between the stock looking hood and the cowel. Do y'all think a cowel would cost more than an aftermarket stock replacement hood. Sorry if this is confusing hard to explain in writting.
    Thanks,
    R.
    RChevy.48
    2001 Silverado RCSB 4.8L
    Current Mods
    Flowmaster Exhaust
    LT1 Fans
    vette cam sitting in garage
    East Coast
    I do believe goodmarks are 450 for a cowl hood. Your stock hood is probably 350-400..
    91 s10 - bagged and bodydropped...getting rebuilt
    91 nissan - backhalfed and bagged
    Apr 2003
    Wylie, TX
    Stylin sells them for $399, and I think I have seen them for as little as $379. Either way it has to be aftermarket, whether its a cowel or stock looking.
    RChevy.48
    Current Mods
    Flowmaster Exhaust
    LT1 Fans
    Jasper, Ga.
    Ask and research. You may can find the hood you want and have them paint it for real close to the price quoted. Find out what the stock hood cost and ask them what would happen if you bring them the hood. If the hood is damaged how about the roof? If I was real tall I might could see the dents. I know I seen them before can not recall where but I will post Monday. Most of my stuff is done at work.
    1999 Silverado 1500 Ext. cab Red 2/4 hotchkis drop & swaybars, bilstein stocks, AR626 & 404 Nitto's, Yank converter, ASM headers, ASP underdrive pulley, Taylor wires , free mods VCN 2000, Nelson Performance tuning
    2002 Red WS6 M6; Flow master K&N
    San Marcos Texas
    Sounds like a good time to upgrade to a cowl hood and just pay the difference.
    San Antonio, TX
    you know what they say, since it's apart i might as well ...
    hahah,
    i say upgrade it the difference isn't going to hurt your wallet too bad, it would be a perfect time
    good luck,
    allen
    Apr 2003
    Wylie, TX
    The guy didn't say to much about the roof, I guess you can't replace the roof. I will check around, the original quote from insurance to fix the hood alone was aprox. $400. I saw a place on the internet that was selling stock hoods for aprox. 140, if the difference is going to be $250 I can't afford that right now.
    RChevy.48
    Current Mods
    Flowmaster Exhaust
    LT1 Fans
    San Marcos Texas
    What about those paintless dent repair places? I've know some used car dealers who used them and the cars came out great. Just a thought.
    May 2003
    Tallahassee, FL
    if the insurance company qouted you $400. then I figure you'll be out maybe $50-$75. that's considering that the hood alone will cost you ~$375, then figure in painting it should be $75-$100. Unless you're running real tight money wise, now is the perfect time to get the hood. When else are you going to be able to get a $400 discount on a hood?
    1989 GMC 1500 f/s stepside reg. cab--4.10's w/Eaton posi--Swapped in LT1--T56 w/SPEC clutch--LT4 Hotcam Kit--Lt4 km--Vented opti conv.--Meziere h2o pump--Taylor over-the-valve-cover wires--K&N CAI--Dynomax coated mid- length headers--True dual Flowmaster 40's no cats--Pcmforless programming
    323rwhp/332rwt
    13.5 @ 98 1.9 60' (with old 700r4 and ET Streets)
    1998 Z28 A4--stock
    Apr 2003
    Wylie, TX
    My insurance said it could be done paintless dent repair, but that was just them looking at it in normal light. I took it to the body shop I use, he does do paintless dent repair which is what he would have prefered to do, but after looking at the hood under UV light he said there were way too many dents for that, it would be cheaper to replace the hood. Thanks for all the info, I guess I will just need to sit down with the body guy and run the numbers.
    RChevy.48
    Current Mods
    Flowmaster Exhaust
    LT1 Fans
