Results 1 to 10 of 12
Thread: 15''
    ff_jeff Guest
    15''
    ok I found a deal on some used 15'' hoosier slicks. They are either 26x8 or 26x10 not sure exactly but will find out tomarrow. My question is will the older 15'' 6 lug wheels fit on my 2004? I thought they would but not sure because I have never compared the 2. Also if the slicks are 26x10 can they fit on 8 inch wide rims? and also if they are 26x8 will they fit on 10 inch wide rims? sorry so long but Im trieng to get ready to race this big bitch.
    Do you have discs or drums in back?
    ff_jeff Guest
    disks...
    Aug 2005
    St. Anthony, Indiana
    don't put a 8" wide tire on a 10" wide wheel.
    Aug 2005
    you can put a 10" wide tire on a 8" rim.
    jeff go find a set, an put them on and just see.
    They won't fit. You need a specific I.D. for the wheel, and a 15" ain't gunna cut it. I have 4 wheel disks too, and my truck cam stock with the 16" wheels.
    Sep 2006
    THE 405
    you can grind down the back calipers like everyone else does. i like that mine came with drum brakes for only that reason
    midweststreetcars.com
    ff_jeff Guest
    what exactly do I need to do to make the wheels fit? what needs to be ground down?
    Slimsilverado Guest
    Jeff just go buy the damn rims from a junk yard and bring them over and we can grind the calipers down to make em fit. I also have a sand blaster. Just buy a few bags of black diamond media and you can blast them then primer and paint at my house.....
