Sorry for the ****ty pictures. They were taken with my phone.
Welded and painted my buddies pan
and then colormatched some of the interior or my othe rfriends truck. There is NO texture it was all taken out.
this is why i should work part time in a paint shop EF!!!! im tired of my stuff not bein smooth.
how much would something like that cost me mayne, cuz ive just been using duplicolor rattle can of course.
To do the entire INSIDE of your truck. Ill panels and all plastic pieces your looking at around a grand. Now we could work something out. If you want to sand all the primer down to get the texture out you could run down here on weeekend. We can get everything primmed and you could bring it back when you get done sanding it all. Itll run you around $600. It is a TON of work.
beautiful work. always seeing these threads make me want to get my shaved tail gate more an more![]()
red 03 thats some nice work man that dash looks sweet.i like the pan too.im gathering your a painter .lol.na looks awesome tho.
