Results 1 to 10 of 16
Thread: Does New Cam = New Lifters?
    Spring, Texas
    Do I have to get new lifters going from a stock cam to a .220/.220 .581/.581 115 lsa Comp? I already have the Patirot dual gold springs and titanium retainers and I plan on upgrading rods. Anything else that I may have missed??
    Mar 2006
    Dawson Springs KY
    Factory roller lifters can be safely reused.
    2011 Silverado LT 5.3 bone stock (for now)
    (gone but not forgotten)02 Avalanche Z-71 Vortech supercharged 3.12 pulley 10psi, SMC meth injection, 33 12.50-17 procomp AT, 17x9 procomp wheels, AVIC-N2 NAV, 4.56 gears, Detroit TrueTrac, 2500 stall converter, transgo HD2 shift kit, Vette servos, 80mm BBK throttle body, Edelbrock shortie headers Cold Fusion wet shot (60hp), and too many more mods to list. 8.86/18th 472rwhp/499rwtq
    May 2007
    <div class='quotetop'>QUOTE(ramair2002 &#064; May 15 2007, 10&#58;30 AM) [snapback]93467[/snapback]</div>
    as long as you don&#39;t exceed the amount of press. a stock lifter can handle you&#39;ll be fine. i know the camaro guys get away with those cams all the time so why can&#39;t you. when you say rods do you mean pushrods?
    Spring, Texas
    <div class='quotetop'>QUOTE(imperial07 &#064; May 15 2007, 12&#58;44 PM) [snapback]93500[/snapback]</div>
    Yep, new pushrods. I&#39;m told that they are a must.
    May 2007
    <div class='quotetop'>QUOTE(ramair2002 &#064; May 15 2007, 12&#58;50 PM) [snapback]93501[/snapback]</div>
    i know guys that got away with it in the f-bodies and vettes but i would never recommend it cause the new cam will spin the motor higher and faster so they are a good investment and a safe bet for a little extra money. how many miles are on your motor? that also determines if you need new lifters or not.
    Spring, Texas
    <div class='quotetop'>QUOTE(imperial07 &#064; May 15 2007, 12&#58;55 PM) [snapback]93502[/snapback]</div>
    I&#39;ve got about 63k on the motor.
    May 2007
    <div class='quotetop'>QUOTE(ramair2002 &#064; May 15 2007, 01&#58;08 PM) [snapback]93503[/snapback]</div>
    you should be good, i say should be because we all know mechanical things can go out at any time even with out mods. but you going to love a cam especially with that turbo. is that cam meant for a turbo motor or is that just a off the shelf cam? just curious cause even the cam i have for my LT1 Z28 has a split profile and its for N/A or a small shot, but its a solid roller.
    Spring, Texas
    <div class='quotetop'>QUOTE(imperial07 &#064; May 15 2007, 01&#58;24 PM) [snapback]93504[/snapback]</div>
    Talking with Allen at Nelson, he says that it is good for a turbo. I think Foggy and several others on this site have the same cam with their turbo.
    May 2007
    <div class='quotetop'>QUOTE(ramair2002 &#064; May 15 2007, 02&#58;02 PM) [snapback]93511[/snapback]</div>
    ok just asking cause one of my camaro buddies has a sts kit and was going to go with a off the shelf cam that was for N2O and it was going to hurt more than help him.
    May 2004
    Pushrods and springs are what you&#39;ll want with the cam since you already have the reatiners. Your lifters are plenty fine for that lift. Alot of guys run the .220/.220-581/581 cam on 112 LSA and that might be what&#39;s hurting them. I think the 115 LSA would be better eventhough the cam I&#39;m running now is a 228/ 232 588/575 - 113 and is a boost grind also.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
