If that's the case then he's probably expecting me to hook this to the module.Can't get him.Wonder what he expected me to hook the wire to.I'll check the resistance on the wires.Paid $750 for the harness to be right.Hope it is
Willie
1626D says its not pulsing the injectors even if the starter circuit is by-passed.Going to have to get the right signal from the Vats module.Looks like Oscars left something out.Probably in the box with my O2 sims,speedo and cruise motors.
damn man. did he build you a custom harness or did he modify one for you? i had a fully custom one built for 750. i just had to buy a little vats bypass module seperate.
Had him graft my El Camino harness into the Firebird harness.Was supposed to get a speedo motor to run the speedo.A cruise motor to run the cruise,O2 sims to get rid of the cats,bypass the VATS and the EVAP.Hasn't sent the speedo and cruise motors or the sims.Sent him the tire size and gear ratio to calibrate the motors,but haven't heard anything from him.He should have got that info when I sent the harness in the beginning of Nov.instead of waiting till I got the harness back,and I sure don't understand why he at least didn't send the sims.Bandit said he'll get me a by-pass kit.Got a message to him now.This has been a major pain.Should have done it myself.
Willie
So far it looks like he did a decent job,a few screwed up things,but it sure as hell ain't no $750 worth.Maybe feel better if I get rest of my stuff.Sure don't want to make a trip to LA.
Willie
Well,Oscar says he's sending the motors and sims on Wed.He sure is a nice guy when you're talking to him.Looks like he's answering the phone more often too.Anyway,going to send VATS by-pass kit today,so maybe it will run longer than a few seconds pretty soon.
Willie
he wasn't too nice to me on the phone, especially when he was threatening to file charges against me for putting down his business.
That's not good,but people say things they don't mean when they get angry.I try not to do that
If I get my motors and sims in I'll feel like I got my $750 worth.I don't see where I'm going to connect the speedo motor though.There's no wire marked for it.Might have to get the wiring diagram out again.
I was going to have him do some more harnesses,there's noone around here that does swaps.We've got one performance shop that does rice burners.I don't have time to do the wiring.That's why I sent it to Oscar.Might have to make time if he doesn't get it together.
When it comes time this summer when i need my harness, im probably going to have speartech do it by the sounds of all this so far. My harness is going to be a lot more complicated, I have a list written out of everythign I need done, I don't think Oscar could handle that. I don't think it's that he doesn't know what he's doing... it's the NUMBER of requests he gets. Maybe he should stay away from that damn ebay and get us happy first.
Mines going together pretty good
I found Oscar through e-bay and he turned me on to LS1truck
I think he needs to hire an assistant for the
and concentrate on the jobs.Maybe slack up on e-bay some.
Willie
- You may not post replies
- You may not edit your posts
