Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Need accessories soon!
    College Station, TX
    Naw I think I would need a 99-02 harness since its an 02 engine and a 01 comp?
    Apr 2006
    <div class='quotetop'>QUOTE(Aggie &#064; Apr 10 2007, 02&#58;09 PM) [snapback]89393[/snapback]</div>
    Yes, but the 03+ fuseblock/body harness won&#39;t connect to an 99-02 engine harness. I had this problem on my 99 when I swapped in an &#39;04 lq9. The &#39;04 harness wouldn&#39;t connect, so I got an &#39;01, and switched the motor over to a cable throttle. It was pretty easy to do, but just meant I had more parts to buy.
    I&#39;ve still got the harness and all the DBW stuff if you need it.
    '99 GMC RCSB
    3" Body lift, 4" Rancho lift, Fox shocks
    36" BFG All-terrains
    LQ9 6.0L swap, gt2-3 cam, longtubes, LS1 fans, Nelson Performance tune
    4.8 gears/Eaton posi
    Built 4l65e
    Custom paint, roll pan, filled tail lights, relocated tail gate handle
    Future mods:
    Boost!!
    College Station, TX
    <div class='quotetop'>QUOTE(tenshikurai &#064; Apr 12 2007, 08&#58;43 PM) [snapback]89741[/snapback]</div>
    The 04 harness you mean?
    Will it fit on everything?
    03 chevy
    02 lq4
    01 PCM (gonna get it from slowz71)
    cable throttle(getting from him again)
    4l60e?
    Any cuts?
    Thanks for the info man...Luckily I didnt go ahead and get a harness from someone haha..
    Sep 2004
    Breaux Bridge, LA
    you need a harness from a 99-02 truck which are 512kb pcms (red and blue connectors)
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
    College Station, TX
    Will the fuse box or anything be different?
    Apr 2006
    <div class='quotetop'>QUOTE(Aggie &#064; Apr 13 2007, 02&#58;49 PM) [snapback]89856[/snapback]</div>
    I don&#39;t think you&#39;re going to be able to use a cable throttle body. I don&#39;t know that any 03+ harness was ever setup that way. So you&#39;d have to run the drive by wire setup, or get a custom harness made by Nelson. I&#39;m not sure about the ECU, but the &#39;01 ecu in my truck has different connectors then the &#39;04 harness. The motor should work with a newer harness, the only differences I ran into were the connector on the oil pressure sensor was different and the &#39;04 motor doesn&#39;t have an EGR. I bought the correct oil sensor, and didn&#39;t worry about the EGR.
    I&#39;ve got the &#39;04 harness, DBW pedal, TAC module left over. I don&#39;t have the ECU or throttle body. If you want it, I&#39;ll send it to you for &#036;100+shipping.
    '99 GMC RCSB
    Built 4l65e
    Future mods:
    Boost!!
    College Station, TX
    I believe all the V6s are drive by wire...I know my 03 engine is...
    I will let you know though&#33;&#33;&#33;
