Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: Here is my dilema...
    <div class='quotetop'>QUOTE(shwarmy &#064; Feb 28 2007, 03&#58;22 PM) [snapback]84776[/snapback]</div>
    The modification i was talking about on the throttle body was to run the cup of the bottom blade of the butterfly. I did this when i had my 4.3 and it made a huge difference in throttle response. You just have to be really care when you do this mod to not cut in edge of the throttle blade. Ducky look on your throttle body and you should see what i am talking about on your blade.
    What do you mean by run the cup?
    Jul 2006
    College Station, TX
    Sorry. Correction is "Remove the cup off the bottom of the throttle blade"
    2004 EXC Silverado 6.2L
    Mods:
    I thought about doing that a while back. Just never got around to it. If it takes less than 30 minutes ill do it...
    Jul 2006
    College Station, TX
    All i recommend doing is taking the throttle body apart when you do it. Trust me this is the best way to do it.
    Mods:
