Results 1 to 10 of 17
Thread: best oil MOBILE 1?
    Oct 2003
    San Antonio TX
    Going to do oil change. Thinking of going with the mobile 1. Is it worth the price? I do an oil change a month do to my job. I drive 3000 miles a month. Will this oil last longer or go farther than 3000 miles. And which grade 5w-30 or 10w-30 or different one??? OR is there a better oil than Mobile 1??
    2003 RCSB 4.8L 5speed, BLACK
    3.42, AIRAID, loudmouth exhaust
    Nelson Performace Tune
    2000 vett cam
    160* stat
    et 14.80@94mph
    Apr 2003
    Wylie, TX
    I had read an article recently on the internet. The guy said that there probably isn't any difference in the different manufacturers of oil, as far as which on is better. But did say that you should try and stay with the same brand as much as possible, due to diff manf using diff additives in there oil. He didn't say there is really any research to prove this, but recommended it because the diff additives may not work well with each other.
    My father in law and I use Quaker State and it seems to be working well for us, they seem to have good prices too.
    RChevy.48
    2001 Silverado RCSB 4.8L
    Current Mods
    Flowmaster Exhaust
    LT1 Fans
    vette cam sitting in garage
    Oct 2003
    LaPorte TX
    I use Royal Purple 10W-30, and have for the past two years that i have owned my truck. I change the oil every 6,000 miles and the oil filter(K&N) every 3,000. this is the suggested intervals from Royal Purple them selves. I have not had a lick of problems out of it yet. Motor runs just as good as the day i bought it.
    1999 Pewter Z28
    Sold - 2001 Onyx Black Silverado Stepside "Thunder"
    Jasper, Ga.
    Why is it that in the old day they would let you change your oil ever 5,000 miles and run leaded gas? Is it because of more 4 bangers that rev higher? I use mobile1 5-30 and change it 3,000-3,500. I heard the same thing as Rchevy about use the same brand.
    1999 Silverado 1500 Ext. cab Red 2/4 hotchkis drop & swaybars, bilstein stocks, AR626 & 404 Nitto's, Yank converter, ASM headers, ASP underdrive pulley, Taylor wires , free mods VCN 2000, Nelson Performance tuning
    2002 Red WS6 M6; Flow master K&N
    Apr 2003
    South MS
    Depends on if you are going mineral or synthetic. I run the M1 Synthetic and can go up to 5000 miles without it getting real dark. I normally change it every 3300-4000 though. I normally run the 5-30 but in the extreme summer months I step up to the 10-30.
    2000 Silverado, RCSB, 2wd w/ a few mods.
    Best 1/4 ET: 12.09@111.22 (old 5.3L H/C/N2O setup)
    WRE 370 and Kenne Bell 2.8L installed and breaking trannys.
    2001 Tahoe LT 4wd
    Stock, daily driver and tow vehicle.
    May 2003
    Sunny San Diego,Ca.
    DITTO
    00'ECSB 4.8L, Auto 4L60E with Fully adjustable TRANSGO shift kit with Superior billet servos, B&M tranny cooler, 4:10's,eaton posi, K&N Gen. 2,Thorley Headers, ASP Crank pulley, LT1 Fans, 3" catback single flowmaster 40 series exhaust, NELSON PERFORMANCE PCM BADASS TUNING, egr trim. Jantzer performance Ported TB, 20x9 MKW's, 2/4 drop.sold
    2006 GTO A4,HPE S+ cam,Volant, Kooks LT's, Magnaflow 3in.Catless cat back,3200 Fuddle converter,UDP. 7.49@93.57
    Coming up= Fast intake and heads.
    Sep 2003
    Cedar Park, TX
    pick one and stick with it. I will put my vote towards Mobil1 though. I always used it on my '98 since I bought it new and when I put the cam in at about 80k the lifter valley was clean and the lifters came out with no problems. No coking or residue. I use it in my truck.
    '02 1500HD, 6.0L, magnacharger, 2000stall, custom magnaflow with electric cutout, E-fans, Nelson custom tune, Auburn LSD.
    '79 L82 vette, Summit 355, Dart Pro1 heads, Comp 274 cam, Holley TBI, Built TH350 with 2500stall
    '93 Blazer, full size 2dr 4x4, new project.....
    Dec 2003
    I only use Royal Purple. You can go 6,000 miles in between, and in gmhightechperformance magazine-It put 5 horsepower at the wheels on the LS1 Engine. Trust me. More power, torque, better gas mileage and better protection. I've been sold on it since the day I tried it.
    2003 Silverado Z71,5.3, 3.73's, Taylor 10.4 mm wires, K&N FIPK, Borla Cat-Back Exhaust, Stock G80 Locking Differential
    Next Mod:
    Nelson Tuning.
    2004 Supercharged Impala SS, K&N air filter, TB screen removed
    Oct 2003
    stuttgart,ar
    What do yall think about mobil 1 15w-50,says it excellent for supercharged & turbocharged engines.I'm thinking about putting this in next time its due.
    It's fully synthetic.
    2000 SWBRC 5.3,radix,e-fans,no cats,true duels
    2 21/2in delta force race muffs,4.10 with eaton
    e-locker.Descreened MAF & throttlebody bypass.
    FLP level 5 4L65E,PI 3000 stall,Dynatech headers
    Nelson tune
    2005 GMC 2500HD 4door 4x4
    1989 Chevy Suburban 4x4 ( Sir Leaks-a-Lot )
    Oct 2003
    LaPorte TX
    1999 Pewter Z28
