Results 1 to 10 of 19
Thread: Iron ls1 into C5?
    Las Cruces, NM
    Iron ls1 into C5?
    Well bought a 1999 C5 with around 160 thousand miles. The Engine does not have the power of an even stock vette anymore. Raced my brothers stock 2002 Z28 and lost really really bad. Vette has ram air only mode. Will my iron 5.7 work on the vette by that i mean oil pan will it fit on the 5.3 block? Also any thing anyone might know please help. Rear end on the vette spent most my extra money on it so trying to use the engine from the truck. Ls1 will be going in the truck. Truck rarely gets used just trying to make this vette my dd and want it fast.
    Wanderer Racing
    2002 Sierra Denali: iron 5.7,cam,243 heads port,headers , true duals, AWD, 42injectors, Nelson Tune, snow performance stage 3,100 Shot of nos, 3200 circle d
    Sep 2011
    It'll swap right over no prob.
    Why would you swap over an iron LS1 when it already has a real alum LS1 in it?
    Just do some mods to the vette and leave the motor in the truck.
    Pittsburgh, PA
    not 100% true, the vette motors have a specific bolt boss in the block for the vettes. Iron motors dont have these and may lead to issues on installment
    Quote Originally Posted by jansen View Post
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Sep 2011
    Quote Originally Posted by George C View Post
    what are you calling a bolt boss? I'm not arguing, just trying to figure out what your talking about.
    Pittsburgh, PA
    its where the vettes motor mount bolts to. most Gen III motors have 4 bosses on each side the vettes have 6
    412 Motorsports
    Round Rock, TX
    The iron motor will bolt right up in a C5. The LS1/6 blocks have 6 mount holes on the driverside and 5 mount holes on the passenger side. It still just uses the front 4 holes like a iron block. The other holes are used for grounds. I've done a couple of these swaps. I have a C5Z in the shop now that just got a 408.
    Las Cruces, NM
    Just the ls1 in the vette no power runs fine no smoke or anything just not enough like an ls1 should be. Also got the engine in the truck brealy finished and never really use it. Use my F-250 more for pulling and stuff. Just want the vette to be my dd with good amount of power. Thanks so by the sounds of it it should fit then.
    Wanderer Racing
    Guess I just dont understand why anyone would want the extra weight of the iron block when you have an alum LS1 already in place. Its just as easy to mod as the 5.3 was. Do some of the same mods and you will get much better gains IMO.
    Mar 2011
    Gibbstown, NJ
    +1
    By the time you pull both motors and swap everything over and install them back into the vehicles you will have spent a month of Sundays with time gone by with neither vehicle running, and not to mention the small fortune in fluids and gaskets that will need to be re-placed, don't forget to factor in the cost of re-tuning both vehicles for proper drive ability. Just mod the motor you have till it blows it up or breaks lol.... or you can install cheap HP on it. Serious doses of N2o till it croaks, then swap motors JMO
    You would only pack on another 30 lbs overall I think as well from swapping an aluminum block to iron block...either way it's really no big deal...Just saying
    2001 ECSB Z-71: 7.0L LS7, Kook's LT's, True Duals, RPM Tune, F.A.S.T. Intake/TB, YANK TT3000, 4:10's, G80, AWD Swap, 160-Stat.....
    Slowest in South Jersey ..........SOLD :-(
    2012 GMC Sierra Z71 CC: 6 Speed, 3:73's, G80, Back up DD...........SOLD
    2000 RCSB Shitbox.......370LSx/Built 60e/4.56's,EATON Posi, CAI,3" SLP Exhaust, DD.......Build Thread http://www.ls1truck.com/forums/my-ga...ker-punch.html
