Results 1 to 10 of 18
Thread: ls1 with 5.3l heads?
    Oct 2012
    Goood combo?
    Arizona/Utah
    Lots of compression very little flow compared to 243s etc
    Oct 2012
    So get 243s?
    Arizona/Utah
    243s and ls6 cam and Walah you have an LS6. I would suggest getting a set of worked 243s(milled slightly and a good p&p) and a good sized cam (226/230 or 224/228 come to mind). Add a triple disk 34-3600 stall and you have a scary fun ride on your hands.
    Dec 2004
    San Antonio, TX Area
    Quote Originally Posted by vtrey View Post
    Goood combo?
    Are you talking about a true LS1? 5.7 aluminum block f-body, corvette style or the generic term used to describe a gen III, IV engine. If so, I've always wondered about 243/799 heads combo package on an LS1.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Oct 2012
    Well this is going in a daily driver I dont want some to crazy I would love for it to be crazy but not with my dd
    Arizona/Utah
    Don't be scared haha it would be worth it. If you want to go more mild then get the 243s milled P&P and throw a mild(216/220) cam at it. No need for a stall and plenty of power to work with.
    Oct 2012
    Ok we got that option or what would I need to get 350 to 400 maybe a Lil more than 400 hp out of a 5.3l
    Arizona/Utah
    Boost or spray are about the only options to get over 400rwhp. Even cam heads and every Bolton on the market you won't likely hit 400. 325-375 is the expected range for a cam and heads 5.3 when tuned well. Most people don't understand what 300+ will even feel like because they don't realize these trucks only put down 215ish stock.
    Oct 2012
    Oh wow ok that makes sence well best option for 350 375 hp out of a 5.3l
