Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: 96,97,98,99 wiring OBS
    May 2004
    There is a major wire color difference in the wiring for the camaro and the 97 truck. I guarantee it will hook up and work right even with mismatched colors. If you get a chance, compare your pinout to a 2002 camaro pinout.
    BTW, just for the hell of it do you have 2 connectors going through your firewall on the passenger side through the P100 grommet? I have a 3 pin black connector 2 grounds and one 12 volt and then a white connector that goes up through the dash back across to the drivers side. I didn't have to mess with anything in there since it was seperate from the engine controls. Thanks for all the comparisons.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    May 2003
    <div class='quotetop'>QUOTE(NITROUS &#064; Apr 9 2006, 06&#58;34 PM) [snapback]49725[/snapback]</div>
    BTW, just for the hell of it do you have 2 connectors going through your firewall on the passenger side through the P100 grommet? I have a 3 pin black connector 2 grounds and one 12 volt and then a white connector that goes up through the dash back across to the drivers side. I didn&#39;t have to mess with anything in there since it was seperate from the engine controls. Thanks for all the comparisons.
    I have 2 connectors going through the firewall on the passenger side. I have the white one, which had the MIL light, and some other small stuff on the dash like oil, air inlet actuator, PND123 selector wires, etc. The other connector was a single pin connector with 12v. Thats the one that has the power for my air recirculation.
    I&#39;ll take a look at my pinouts and compare them to a f-body later tonight. I didn&#39;t think there would be a color difference between the two like that.
    Old: 1998 K1500 White ext cab stepside, vortec 350. Stock besides Volant intake.
    New: 1998 K1500 with stock LS2 besides LQ9 truck intake and 8.1L Marine injectors. Dynotuned, 350rwhp, custom 3.5" exhaust, &#39;02 F-Body Racetronix fuel pump setup. All wiring, exhaust, motor brackets done in shop.
    May 2004
    Check this out, My MIL light from the PCM is Dk Brown where it goes through connector C100. On the 98&#39;s it says it&#39;s not used in C100. Trust me there are some major harness differences between the years. A friend of mine took his 96 V6 out and put in a vortec 350 and the wiring ate his lunch from the differences.
    97 GMC, 2002 LS6.
    May 2003
    <div class='quotetop'>QUOTE(NITROUS &#064; Apr 9 2006, 09&#58;35 PM) [snapback]49742[/snapback]</div>
    Yea, the &#39;98s the MIL runs in through the connector on the passenger side. Definately sounds like some big differences
