Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Remote Start
    Mar 2010
    Paris, TX
    Yep
    Feb 2011
    Barnwell, SC
    Good info to know. My wife is wanting remote start too. Which one did you go with? I've never looked into them so I have no clue.
    Jun 2011
    Rogers, Ar
    Not to thread jack, but does anyone have experience with a remote start that uses the factory key fob they want to recommend?
    Mar 2010
    Paris, TX
    I used a cheap eBay remote start that works off the door lock wires/uses factory remote. However, the down side is if you play with the door locks from inside the truck it will crank just like using the remote.
    99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=7887&dateline=1270435  715
    Broken Bow, OK
    You can use the resistor (not diode) method on the trucks just like you can the older PASSLOCK I stuff. The only difference is the resistor is in the steering column rather than in the key like on the older stuff.
    Program it out and you are done.
