chevrolade if you ever get sick of looking at that truck you just pm me i will have to own it it is my favorite on here.
axles are usually broken on launch, going forward, i chose to go Yukons, theyve seen over 600 and some hard launches, so did the stocks, i changed them for the simple fact i had a small seal leak ( wear ) on one side. will they hold on the new setup i doubt it, but i wont change them until one breaks
Zach i doubt you'll have a problem just dont see your setup launching harder than a nitrous setup. unless youre spraying out the hole and cutting some serious 60 ft times.
Simple: 408 on steroids!
single digits coming soon!
The 99-06 axles are not the same as the 08+ just FYI.
single digit street truck
for build info
are the 08+ weaker? reason i ask im fixing to drop a 6.2 and probably run a tvs or procharger for the torque, going after high torque numbers this go round on my 09 truck
Not sure, the red truck allen has broke one just making a pass....
for build info
the nbs 07 and up are longer and the thikness is alot bigger. That axle broke on a weak 10 second pass
I'll be upgrading axles for extra insurance and so my rear bogart won't beat me to the finish line
I would look into c-clip eliminator axle setups.
