Results 1 to 10 of 62
Thread: Master cylinder for a T56?
Threaded View
  1. #13
    Oct 2008
    Tennessee
    pnhigg
    Were you able to use same drive shaft from 305/5sp in 5.3/6sp? I can never shift fast from 1 to 2 without letting up on gas. I wonder if you had same problem w/5sp. I see on Ls1tech there is a
    fix to drill a larger hole to pass more fluid.
    90"rado
    What year truck did 14 bolt come from? Bolt pattern problem?
