Gonna run a compression check on my 4.8L. Just wanted to know what the normal cylinder psi should be when I do it.
Should be around 170 or so.
mine is only 155???? in my 4.8 i mean 408 ...... remeber your last cylinders may be a little less if the battery gets low.... dont let this alarm you
Mine were 165-170 last time I checked and the bad one was around 90 or so. It will be evident if one is off.
Well, all cylinders were between 160 and 190. I'm assuming the higher cylinder pressures were due to excess carbon build up on the piston heads. Gonna fire it up as soon as my rebuilt turbo arrives and gets installed.
sounds good
Wish me luck guys. It's Monday night and all I have to do tommorow is install the rebuilt turbo. Then it's game time for my engine after the broken rocker arm episode. I'm tired of driving that damn SLOW-bra so with any luck, my truck will be back on the road soon.....and did I mention my truck is faster than that damn SLOW-bra???![]()
