Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: my 408 dyno
  1. #11
    that thing is pretty dang sweet
    Spring, TX
    Holy crap, that thing is amazing
    ^Ricky's Sweet PS Skilz
  3. #13
    Feb 2008
    Arizona
    WOW!! looks FAST!! great numbers BTW!! how much NOS did you go for??200hp??
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
  4. #14
    Jul 2009
    kuwait
    Quote Originally Posted by White Devil View Post
    yes it was 200 shot but the heat was killing us its was over 45 Celsius which is 115 Fahrenheit thata why i didnot get the hole 650 hp
  5. #15
    Houston
    good numbers
    question
    did u open the cutouts off the line or did u do it halfway there
    i kno DamnYankee was talking about it makes it worse if u open em up off the line
    2000 Yukon Xl
    2003 Sierra Denali Quadrasteer
  6. #16
    Jul 2009
    kuwait
    Quote Originally Posted by gordo View Post
    good numbers
    question
    it was open all the way what DamnYankee saying is right if you have stock setup but with strocker i think it should be open all the way but i notice if it was open i lose sum power but not for sure its just feeling i realy didnot try haveing the cutout half way on dyno
  7. #17
    Jul 2009
    kuwait
    i want to post the dyno sheet if cant see it just click on the sheet
  8. #18
    Houston
    i would think so i alwayz thought of puttin an rpm switch u know what i mean like install the switch so wen u hit certain rpms the son of a gun will open n scream u kno but idk just a thought
    2000 Yukon Xl
  9. #19
    Jul 2009
    kuwait
    you should but let me tell you what you should do also , you must put a safety switch on the thruotel so the rpm switch dont work when the rpm start going down i had this prblem and i had the bigest blowoff my intake jump out side my truck cuse this rpm switch will work btwen the number you set it going up or comeing down so the safety thruotel switch is a must must must what i mean you must hit the gas all the way down so the switch opin and then the rpm switch start working and when you realse your feet from the gas thruotel it will stop
