Results 1 to 10 of 17
Thread: So many things wrong with my truck
    Houston
    So i get picked up in my truck from school by my brother (His is in the shop)
    so he gives me a little slip from Auto Zone and it reads
    TROUBLESHOOTING
    -Catalyst Efficiency low- bank 1
    Explanation
    The oxygen sensors monitor the Catalytic Converters ability
    to score oxygen
    Probable Cause
    -Catalytic converter defective
    -Engine misfire or running condition
    -Large Vacuum leak
    -Engine oil leakage into exhaust - valve guide
    seals, piston rings
    So i guess i have to change out my O2 sensor on bank 1 right?
    2000 Yukon Xl
    2003 Sierra Denali Quadrasteer
    Quote Originally Posted by parentsyukonnowmine View Post
    TROUBLESHOOTING
    Explanation
    to score oxygen
    Probable Cause
    -Large Vacuum leak
    seals, piston rings
    Your catalytic converter is toast (most likely), cut them out and get the rear o2 sensors shut off in a tune, the front o2 sensors are what monitor the A/F ratio, rears just keep tabs on the cats.
    Houston
    ima just try to change bank1 and see if that'll shut it up if not
    ima do that and hit up Flaco for a tune
    2000 Yukon Xl
    Don't waste your money. I have never seen another cause for 420 or 430 than a bad cat. Do not replace an O2 in hopes of fixing this. Get the cats gutted and the tune adjusted to ignore the rears or put new cats from GM on there. Aftermarket cats will cause these codes eventually too.
    gut the cats,get tuned
    Houston
    damn but its a lot of cash i dont have right now
    dude game me a print out of the whole cat im guessing its the y pipe it includes the 2 cats
    its
    MAREMONT
    Converter-Catalytie
    Retail:359.99
    5 yr warranty
    then a tune wit flaco is another $250
    thats almost $700
    Still in High School ppl im broke
    2000 Yukon Xl
    Spring, Texas
    I've got a y-pipe with the cats gutted but still intact, if that makes sense, that I'd sell you. But if you need cats for emissions, it wouldn't help. Plus, it's off my 04 and don't know if it would be the same as yours. Just thought I'd offer though.
    Feb 2009
    Houston
    what happen was back acouple years ago when me and a buddy replaced the transmission we striped two bolts on the driver side exhaust. were the header and the cats meet.so i think only one is tight. willl that cause the truck to throw the codes?
    Houston
    how much we talkin bout?
    2000 Yukon Xl
    Wasilla, AK
    X2, only a cat problem triggers this code, never an O2.
