Page 17 of 52 FirstFirst ... 7 15 16 17 18 19 27 ... LastLast
Results 161 to 170 of 518
Thread: 1/4 Mile - LS1Truck.com Fastest Truck List
  1. #161
    Yessir. There's a lot left on the table there with that 2.35 60'. Once you get the new trans in and some traction it should pick up a good bit.
  2. #162
    well... even with this update I'm still second to last on the list... lol
    R/T ... .318
    60' ... 2.446
    330 ... 6.759
    1/8 ... 10.301
    MPH ... 70.07
    1000 ... 13.317
    1.4 ... 15.865
    MPH ... 87.83
    *Edit*
    Volant CAI, w/ ram, Nelson Tune, True Dual Exhaust with Flowmaster 50 series (boo), OBX Headers, e-fans....
    Guess its times to wait for it to get cold....
    MKader17
  3. #163
    ff_jeff Guest
    Quote Originally Posted by MKader17 View Post
    R/T ... .318
    60' ... 2.446
    330 ... 6.759
    1/8 ... 10.301
    MPH ... 70.07
    1000 ... 13.317
    1.4 ... 15.865
    MPH ... 87.83
    What all did you change from the last time? thats a good mph and et for that truck...
  4. #164
    Da-Mo
    R/t .3344
    60ft 2.2687
    330ft 6.4366
    1/8 9.88 at 72.71
    1000ft 12.59 at 83.74
    One wheel peel(3.42's) cold air and true duals with some knock off flows. Sorry on the lack of the 1/4 time, track I go to is just a 1000ft.
  5. #165
    Da-Mo
    5.3 stock trans and rear end
  6. #166
    editted the original post and thanks! I expected around .4 seconds faster though and it really doesn't seem like I could improve my launch
    MKader17
  7. #167
    ff_jeff Guest
    Most of the time you shaved was because of the tune. LT's and a smaller tire setup will help allot. what size tires you running now? BTW dont worry, starting on bottom just means you will improve more.
  8. #168
    The OBX Headers are long tubes. Right now I think I have tires that measure out to a lil more than 30".
    MKader17
  9. #169
    got it all updated!
    ff_jeff Guest
    cool, You could do Like I did and get some smaller tires. Be better to get gears, but 4wd gears are $$$. I think some 28'' tires would be good.. your speedo will be off a little though.
