:bsflag:I dont think that you hit some some other car, I think you need to de-mod your truck cause it was so fast it damaged the front end lol!
Glad you are OK. You radiator core support is for sure bent and will need replacing. Make sure and have the adjuster do a visual on the front frame rails too, they may be a little bent. If he sees no damage to them then the body shoop needs to put it up on the frame rack and check the measurements to make sure they are with in factory spec.
All in all the truck can be fixed and you are OK which is the most important thing. Your looking at $2500-$3500 in damage may be a little less just my guess.
Again glad you are OK.
2005 Crew Cab 1500HD aka "Big Beast"
6.0L Cam'd & turbo'd **SOLD**
'03 Cummins straight piped and a programmer
"I bought a Cummins and it came with a free Dodge!"
