Results 11 to 20 of 29
Thread: '86 C-30 6.0 LQ-4 Swap question
    NW South Dakota
    It lives...started this thing yesterday. So far am extremely leased with this swap.
    OK...first off I want to thank everyone who helped with ideas. It made this a lot less painful.
    I have one more question though.
    I'm sure some of you guys run the factory dual tanks on these models for your swaps.
    I have installed 2 EP 381's (1 in each tank), (I used a factory 1987 tank switcher valve) when I fired it up I didn't have enough pressure...about half of what it is supose to have, 32lbs.
    I byassed the switcher valve and I have the full 62lbs like I should have.
    My questions are...do I have a bad valve???
    Or...are you guys using a different way to switch your tanks??
    I've searched alot...but haven't ran across anything on this.
    Maybe these valves were only made to support the lower pressure TBI system.
    My valve came from NAPA PN 22198...
    It had a sticker on it that said "Do not exceed 68 PSI" so I figured I should have a small margin of leway with it being that I'm at 62 PSI.
    I'd like to here from anyone that's running dual tanks on this one.
    Again, thanks in advance, Mike.
    Hurley, Mississippi
    I did the same swap and used the f body too. Wanted to do headers, but wasn't sure. That's on the to do list for upgrades later.
    '86 Silvy- '06 6.0/4L80E, K&N, 2.5 X-pipe Magnaflows, 20" Foose Wheels, Auburn Pro, 3.90 Richmond Gears, and the list is growing!!!
    Hurley, Mississippi
    I didn't go with in tank set up, used a inline that works but I don't like the noise. Please post the final set up? Is the wiring setup from the 86 to the 87 a big deal?
    NW South Dakota
    Quote Originally Posted by HarleyDave View Post
    I didn't like the noise of the inline on my racecar either...so I went inline.
    Will do.
    Not to bad...I did run heavier gauge wire back to the pumps, as on an 86 all the wires do is switch the tanks. (They dont have to run any pumps).
    Hurley, Mississippi
    So how do you control the pumps is there a relay for the 87? or did you just run a switch?
    Aug 2006
    FYI,
    there are headers out now for the swap.
    The LS1 swap headers are done!!!! - The 1947 - Present Chevrolet & GMC Truck Message Board Network
    I am picking up the prototypes this weekend to test fit on my 86 6.0 swap..
    Wouldn't it be easier to just use the fbody long tube headers? They bolt right in place.
    NW South Dakota
    I used a combination fuel pump and relay fuse block from an Olds Cutlass Supreme to run my fuel pumps, looks nice...works great.
    Quote Originally Posted by pcmcobra View Post
    FYI,
    I'd really like to see what these look like installed on your '86.
    Aug 2006
    Quote Originally Posted by CattleAc View Post
    I'll post pics as soon as I get the motor in and headers on. Having a little trouble "recruiting" help...so it might be a couple weeks...I can't stand it!
    Aug 2006
    Well, I guess a lot of things "could" be easier...I like the look of these headers, just giving out some info, a new product not many swappers might have heard about.
