Originally Posted by
ChevyLee
i checked for coolant in my oil, the oil looked fine. it wasn't milky at all. i didn't fill the coolant in my reservoir when i did the flush a last month when i did the water pump swap. i will fill that thing up, maybe it should go away.
thanks to everyone who posted up
-jeff, i hope its not that bad
the truck only has 57xxx miles on it.
make sure you purge -burp out the lines when yoou add coolant ,ive had oveerheating issues just because of air in the coolant lines .but first change that heater core.lol.what a bitch.
