Originally Posted by
farmtruc
Brand new , in the box, never opened!
$499 plus shipping takes it!
This kit is good for 125HP. It's a great kit for any of our trucks, even forced induction. If you're not familiar with ZEX, check it out:
A complete "Wet" nitrous system. Everything is included for a safe, proper installation.
• Designed to work safely on stock type engines, but is also engineered to perform flawlessly on highly modified turbocharged and supercharged combinations. The ideal nitrous system for any fuel injected vehicle.
• All major components are factory pre-assembled inside the "Nitrous Management Unit". Easy, plug and play, two-hour installation.
• ZEX Nitrous Systems have an advanced, patented feature called "Active Fuel Control". This feature monitors nitrous bottle pressure and adds or subtracts enrichment fuel so the engine never runs too rich, or too lean, when you engage the nitrous system.
• ZEX "Wet" nitrous systems activate at wide-open throttle using advanced electronics that monitor your engine's throttle position sensor. This makes using your nitrous system very easy and reliable.
would i need any other accessories to go with this ,like purge ,heater ,etc to be totally safe,window switch.?
