Results 1 to 8 of 8
Thread: 4/6 drop and towing questions
    Ok, these might be a few stupid questions. I am planning on doing the 4/6 drop on my 92 scsb. I will be doing the lq9/4l80e combo.
    Would you guys go with the z06 cam? if not what cam would you recommend for towing and have some power?
    Has anyone done any type of towing with this drop? would it be recommended? What is i use air over leaf helper bags?
    Also what gear ratio would you guys recommend to keep decent miles, and have the power to tow?
    I will mostly be using the truck as my daily driver.
    thanks
    Nov 2005
    if your using a flip kit for the rear, towing should be fine depending on what you are towing..i have the hanger/shackels and lowering leafs because i didnt use a flip kit the frist time i lowered it. but i still pull a seadoo and i put a 300-400lbs gun safe in the bed once and it was fine. good luck..
    Project: 91' short wide:
    GMC front end update with billet grille and all clears, 17x8 & 17x11 Torq Thrust II's
    5/7 drop, almost totally shaved and 93 Deville tails
    Future Plans: 2001 LQ4 6.0L & a T-56
    DD: 98' 5 speed GT : Dumped Exhaust, CAI
    i will be towing a 1991 GMC syclone. So that truck is 3800lbs and the dolly is 1200. so 5000lb towing. I also have a 98 dodge ram, with a 5.9. But wanted to tow with style and have it able just incase i sale the ram.
    May 2006
    Waco TX
    Wouldn't it be easier to do an LQ4-80E swap instead of an LQ9-60e/65e swap instead of a LQ9-80E?
    Nov 2005
    yeah you should be fine..there is a guy on gmfullsize.com i think that has a 4/6 kit and tows his c1500 on a car hauler...you sould be fine as long as your wheels dont rub
    Dec 2003
    Azle,TX
    Gabreil air shocks...56.99 at autozone they work great
    Vortec Performance Tuned
    <div class='quotetop'>QUOTE(Red03SilSS &#064; May 23 2007, 04&#58;00 PM) [snapback]94463[/snapback]</div>
    Wouldn&#39;t it be easier to do an LQ4-80E swap instead of an LQ9-60e/65e swap instead of a LQ9-80E?
    I am doing the lq9/4l80e swap.
    Oct 2006
    <div class='quotetop'>QUOTE(Justblazin &#064; May 23 2007, 10&#58;23 PM) [snapback]94495[/snapback]</div>
    i have a 4/8 and have hauled an engine in my bed with no problems. although its only approx 530 lbs, still had no problem. the flip kit doesnt alter the spring rates of your factory suspension. you should be fine.
    13.4 @ 98mph. Cammed/Stalled/LTs/Tune and those lame 3.42s!
