Results 1 to 5 of 5
Thread: Weird Idle...
    May 2006
    Waco TX
    So yesterday I was on a back road, and I decided to open it up, BC the road is perfectly straight. I got up to around 110 or so and layed off. Came to a stop sign, and My truck was idling horribly!! It was rough as hell. I turned my A/C off and about 2 seconds after that the idle returned to normal. Weird huh? Any clues as to what it may be?
    Jul 2005
    modesto, ca
    I know old post, but this sounds similer to what mine is doing. I pulled up to a stop light and it started chuggin' @ idle down to 250 - 300 rpm, I put it in neutral rev it and it went right back to chuggin'. Then I turned the defrost off and it idled up to normal. It has done this several times lately. I know because of that it had to much load @ idle. In the summer the idle would droop to 450 - 500 and i would just give a quick tap on the trottle and it would correct its self that dosent seem to be working in this case as the droop is geting worse. I have had efans for about 18 months, but there not hooked to the pcm, insted i hooked them to a temp switch.
    If I hooked them to the pcm would that let the pcm be able to correct its self easier? or does it even matter. Is it sad that I own my own danm shop and between me and the three master tech we can't figure it out?
    http://i10.photobucket.com/albums/a1...dited-copy.jpg
    2007 Sierra crew 5.3 4wd, stock for now
    2004 Sierra scsb 5.3 - sold
    02 Z28 SLP cold air pack, Corsa exh, Center Force dual friction + 23 lb flywheel
    66 Chevy C20 (collecting dust)
    May 2006
    Waco TX
    Wow man. Took ya a while to find this one huh?
    <div class='quotetop'>QUOTE(Red03SilSS &#064; Aug 1 2006, 05&#58;31 AM) [snapback]59546[/snapback]</div>
    So yesterday I was on a back road, and I decided to open it up, BC the road is perfectly straight. I got up to around 110 or so and layed off. Came to a stop sign, and My truck was idling horribly&#33;&#33; It was rough as hell. I turned my A/C off and about 2 seconds after that the idle returned to normal. Weird huh? Any clues as to what it may be?
    did you figure this one out yet?
    http://i123.photobucket.com/albums/o...ewody/Wody.jpg
    2005 Silverado SS: outlaw c.a.i., msd 8.5 wires, custom 3" dual exhaust, pacesetter l/t&#39;s, magnaflow highflow cats, magnaflow x pipe, flowtech cutouts, magnaflow mufflers, ported throttle body, 160* t-stat, revolution raceworks tune, precision "big mouth" grille, pioneer avic n-3 nav/dvd, alarm and remote start.
    1931 buick 8
    Jul 2005
    modesto, ca
    Any ideas if the pcm programing would help? Anyone?
