Results 1 to 5 of 5
Thread: Custom Turbo a-la STS style???
    Aug 2005
    Thumbs up
    Has anyone ever pieced together a custom single turbo setup layed out similar to the STS rear mount kit? Looking at used/reconditioned turbo's and wastegates on e-bay, and seeing that I'm already an HP Tuners owner, I couldn't imagine that with some DIY work, a used turbo, and a wideband O2 it would add up anywhere near the STS MSRP. Another note, a custom supercharger setup would be cool too, except used/loose superchargers (centrifugal) are pricey.
    Nov 2006
    Plano, TX
    <div class='quotetop'>QUOTE(esee135 &#064; Jan 30 2007, 01&#58;12 AM) [snapback]81626[/snapback]</div>
    Has anyone ever pieced together a custom single turbo setup layed out similar to the STS rear mount kit? Looking at used/reconditioned turbo&#39;s and wastegates on e-bay, and seeing that I&#39;m already an HP Tuners owner, I couldn&#39;t imagine that with some DIY work, a used turbo, and a wideband O2 it would add up anywhere near the STS MSRP. Another note, a custom supercharger setup would be cool too, except used/loose superchargers (centrifugal) are pricey.
    The turbine housings on the STS are different than what is found on a run-of-the-mill turbo, to deal with the distance it is from the exhaust manifold. Meaning, that if you take a rebuilt turbo meant for use close to the engine and place it remote at the back of the truck it won&#39;t work well. HOWEVER, if you mounted it under the truck near the exhaust manifolds, like right in place of where the facotry cats normally go...
    Mr. P.
    Jan 2007
    check this build= http://www.fuelslut.net/forum/viewtopic.php?t=50211
    He did a "mid" mount setup similar to what Mister P is mentioning. His best time so far in the 1/8 is
    E.T- 8.6286
    MPH-83mph
    60&#39;- 2.13
    RT- .614
    This is his mod list at the time of that run:
    custom rearmount turbo set-up @ 11psi
    base tune (really safe mail order tune)
    Lakewood Traction bars
    B&M shift kit + vette servos
    UD pullies
    OPEN DIFFRENTIAL w/ 3.42&#39;s on crappy falken Ziex tires
    It&#39;s very easy to build a kit like the STS kit, just make sure you get an inline oil pump for the turbo&#33;
    1987 Iroc: :*( Sold
    1998 Sierra Z71: The tow vehicle :evil:
    1969 Pontiac Tempest- the new toy
    http://www.fuelslut.net/ihost/files/8340/slutsig1.jpg
    <div class='quotetop'>QUOTE("Whitey Almighty")</div>
    Ah VTEC. All the lag, none of the turbo. It&#39;s like waiting for bad sex.
    Nov 2006
    Plano, TX
    <div class='quotetop'>QUOTE(1FSTZ71 &#064; Jan 30 2007, 11&#58;17 PM) [snapback]81730[/snapback]</div>
    ... OPEN DIFFRENTIAL w/ 3.42&#39;s on crappy falken Ziex tires ...[/b]
    Agreed - with posi & a little converter that truck would easily have been another .3-tenths faster on the 60-foot time.
    Jan 2007
    Ya that truck has alot more in it and it&#39;s still a stock 4.3 lol
    1987 Iroc: :*( Sold
