Results 1 to 5 of 5
Thread: 5.3L into an S-10
    Will this fit and does anyone have any pictures?
    Will the intake manifold clear the hood?
    Will the oil pan clear the crossmember?
    any info is appreciated,
    allen
    Jan 2005
    Conway, AR
    It will fit but I am not sure about the manifold, let me go dig up where I found this setup.
    Feb 2006
    I'm doing this swap right now, the truck oil pan will work with a little cutting to the crossmember, I believe the hood will clear with the stock intake, I got this link from another forum and these guys have been swaping ls'x engines into s-10s for some time now.
    http://www.s10forum.com/forum/showthread.p...eferrerid=43716
    Nov 2005
    ohio
    It will fit allen, there are some issues with the oil pan in a 4x4 but if need Canton racing products can build a custom one. Ive always wanted to do this project! Go For it. I'll email you some pics i have of a friens S-10 with a built 6.0 in it. BTW He used an LS1 intake for a better fit.
    May 2006
    it will fit.
    Go to yank converters and look at the tetimonials.
    There is a guy w a 5.3 s10 runs real good!!!!!
    http://www.angelfire.com/alt/americanscrapmetal/4.jpg
    2006 Ext Cab LT 1500 4.8 Auto.
    Mods:
    K & N, MAF descreen, Cold air tube, Ported TB, TB Bypass, Predator tuned, No cats, Dual exaust w/Flowmasters, 4.11 Yukons w/posi, 160 Stat, Tranny cooler
