SPOT ON.
Did you guys get that header bolt in the head taken out?
He did. Not sure if it was able to be taken out... Bob said he checked the intake for leaks and came up with nothing.
Since no conclusion has been conceived by now, you are going to have toi go back to the old school way of reading the motor by looking at the plugs. They're black as night huh? Well right there, we know the motor is fueling more than needed. Bob said it is much as ~22% on Bank 1 at idle. The PCM is obviously detecting a lean condition somewhere...or (depending on the condition and settings of the MAF) since we are experiencing colder temps (colder air is more dense, requiring more fuel) the PCM is figuring out it needs a tad bit more fuel and it is compensating.
To get this issue resolved, a scan file needs to be sent to your tuner along with all of the things you have done to help remediate this (cleaned MAF, fixed header leak, changed plugs, etc). He can tell you more about what is going on Real Time than you can...
