Will the 4l80 hook up and will the yoke fit my drive shaft or should I get a different drive shaft or yoke? Thanks!
 Junior Member
						Junior Member
pretty much all GM engines & transmissions will bolt together
a few cargo vans even came with 4.8 + 4L80 stock
you could put a Turbo350 behind an LS9 if you wanted...
there's plenty of threads on the 4L60 -> 80 swap, just dig around & you'll find step-by-step instructions with every part # listed.
ain't sure off-hand about the yoke - but i don't know a whole lot on the automatics
