98 XJ with an 05 LM7 5.3L from a Sierra 1500, 35x12.5" shoes, 4.56 gears, 4l65e1. Swap went smooth (finished around 8-10 months ago).
I recently noticed fuel economy slowly tanking. Was getting 20mpg when I first completed the swap, but sometime in the past few months it's slowly dropped. Currently getting around 16.5mpg highway.
For the past few weeks, I've been throwing a P0327 intermittently. It'll clear on it's own but return a few days later. If I clear it manually, it usually comes back in about the same amount of time.
Tested the KS's by tapping the heads and the front KS didn't really seem to respond reliably, so I swapped out both sensors and harness. Old KS's were rusty as hell, and there was heaps of mud in there, so I gave it all a good cleaning, and built up some RTV dams for both sensors before replacing. Got it all back together, and still throwing the P0327.
Today I had time to do some testing. At cold idle, both KS's are making around 150-100mV. Both respond roughly the same to tapping on the heads. Verified good continuity to the ECM connector pins 11 and 51.
So, I'm already aware of what SHOULD set a P0327 under normal conditions, but starting to think something abnormal is going on. All my grounds seem good, not seeing short to voltage, just can't find anything wrong, other than smells rich, tanking fuel economy, and the P0327.
Any ideas?
