Results 11 to 20 of 29
Thread: 92 pickup 6.0 factory computer
  1. #11
    May 2011
    Throttle cable? Anyone have ideas that they have used that will work with that half moon wrap around style?
  2. #12
    Jan 2012
    warwick ny
    I used a 1999 chevy pickup throttle cable. I just had to file the hole going through the firewall for it to fit. It connects to your gas pedal like stock.
  3. #13
    May 2011
    Like 99 half ton? I used the cable from the 2000 model the motor came out of. But it's just short enough to hold my throttle body open to about 1900 rpm
  4. #14
    May 2011
    i need help with my clutch. im having issues with it not engaging the flywheel. I bought the sachs nfw1050 flywheel from rock auto for the 6.0l. now my trans is a nv4500 from a 97ish diesel Chevrolet. the clutch is a south bend single disc. my throwout bearing is internal. now the first time I mated them up didn't really notice anything wrong. then decided to pull the trans to put in the steel braded clutch line. the end of my throw out bearing tube had contacted my clutch disc. so I bought a new one and measured them. thinking that it was just my south bend clutch may be a little thicker I shaved less than .25" off the end of the tube. put it all back together but now with my foot off the clutch and it in gear it feels like your riding the clutch and slipping it. put it in gear and push the truck you can see and hear the clutch disc spinning.
    now did I order the correct flywheel? or is it too thick causing my clutch to be too close to the trans? or do I have other issues?
  5. #15
    Dec 2008
    South Carolina
    Did you use a spacer?
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
  6. #16
    Dec 2008
    South Carolina
    And what year is the 6.0 you have?
  7. #17
    May 2011
    no spacer. I believe the engine came from a 2000.
  8. #18
    Dec 2008
    South Carolina
    You have the wrong flywheel. The 99-2000 6.0 have a .4" longer crank flange than all the other LS engines. You need a flat 6.0 flywheel. The one you have is offset .4"
  9. #19
    May 2011
    Do you have that part number? Anyone?
  10. #20
    Dec 2008
    South Carolina
    Na I don't have a clue man
