Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 41 to 50 of 55
Thread: Project Sucker Punch
  1. #41
    Mar 2011
    Gibbstown, NJ
    Quote Originally Posted by Wrkd_LSX View Post
    what'd you decide on as far as the drop? cause im in the same boat with my ecsb i was goin to do a 3 inch shackle and remove overload also but im not sure it'll be enough.
    I'm getting ready to update the thread soon, but I went with a 2.5-3" or soo on the rear. Bell tech lower shackle and overload removed. I am going to drop it 2/4 shortly. The " new " wheel/tire combo is undisclosed to public viewers until I update the thread. A few people have seen the new setup since last time I swapped over to black D windows..... New setup and pics coming
  2. #42
    Mar 2011
    Gibbstown, NJ
    Teaser pics
  3. #43
    Mar 2011
    Gibbstown, NJ
    So it's been a while since I have been on here to update the build, the last time made a few post I was finishing my 6.0 swap. Since then I have made some big changes to the truck including home made cal-tracs, LS1 E-Fans, Circle D 3200 stall converter and 5 lug swap..... More pics and updates coming soon
  4. #44
    Mar 2011
    Gibbstown, NJ
    The "new-old" wheel and tire combo
    16x8 4"bs wagon wheels
    The making of the traction bars. I used 3/4" heim joints with 4x weld in tube nuts ( 2x left and 2x right ) and I used 1-1/4 x .120 wall DOM Tubing for the bars, then I made a few different templates out of cardboard for the brackets, which I then transferred onto thin steel to make my patterns then I made everything from 3/16" mild steel plate and welded the drop brackets to the original leaf spring u-bolt mounts.
    TIG the ends on and smooth the welds
    Painted bars
  5. #45
    Mar 2011
    Gibbstown, NJ
    Traction bars installed and 5-lug swap
    Rear 15x10
    New Color - Arrival Blue
    2001 ECSB Z-71: 7.0L LS7, Kook's LT's, True Duals, RPM Tune, F.A.S.T. Intake/TB, YANK TT3000, 4:10's, G80, AWD Swap, 160-Stat.....
    Slowest in South Jersey ..........SOLD :-(
    2012 GMC Sierra Z71 CC: 6 Speed, 3:73's, G80, Back up DD...........SOLD
    2000 RCSB Shitbox.......370LSx/Built 60e/4.56's,EATON Posi, CAI,3" SLP Exhaust, DD.......Build Thread http://www.ls1truck.com/forums/my-ga...ker-punch.html
  6. #46
    Hope Mills, NC
    you ever plan on running this thing?
    2005 GMC RST *sold
    2006 Silverado SS with nawz
  7. #47
    Mar 2011
    Gibbstown, NJ
    Quote Originally Posted by SNEEKY View Post
    Nope ................ Just a street truck
    JK it's going to the track in 2x weeks hopefully
  8. #48
    Mar 2011
    Gibbstown, NJ
    Just a few more pics of the truck and a few runs with the truck on the stock verter
    Circle D 3200 278mm verter for 60e
    Idle clip of hot motor
    35-100 on the stock verter
    60-110 on the stock verter
  9. #49
    Oct 2011
    San Antonio TX
    Looks good. Now put a dam tailgate on that thing lol.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
  10. #50
    Mar 2011
    Gibbstown, NJ
    Thanks man! Haha I would but someone liked it more then me.... Matter of fact they liked it soo much they "borrowed" the mounting brackets as well.
    How's your trucking coming?
