I'm getting down to the final stage of my swap, I have my harness thined out and lengthened/ shortened. So this leads my to the fuse block and relays. I'm going with the lt1 swap setup.
He only has 5 pink wires ran to the block, I have 13 or 15 (can't remember ATM) to run for switched 12v. how did he come up with only 5? Did he splice a few together up the harness to make 5 main groups to run to the block? If so how many can be spliced together with out over powering the main spliced wire between the block and slice?
Also were should I tap for switched power to the fuse block relay.
Thanks guys.
