Results 1 to 9 of 9
Thread: nbs differental into a obs
    Mar 2013
    compton ca
    I have a 06 Silverado ss rearend Nd want to c if it will bolt right up to my obs or do I have to modify
    It's gonna be wider. And no it's not going to bolt up.
    Sep 2011
    Spring mounts and shock mounts in different locations. Although the carriers are interchangeable between the two.
    99 rcsb silverado...... boosted.
    Sep 2009
    NE Ohio
    Depending on the spline count right? I have a G80 rearend sitting in my donor truck, 01 Denali, that I would love to put in mine. But the spline count, if I remember correctly, is different and I wouldnt be able to use my stock axles.
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
    Sep 2009
    NE Ohio
    Should mention that I am 5 lug and 10 bolt housing.
    Sep 2011
    01 has 31 splines axles and the older rear has 28 you would have to have aftermarket axles for it to work.
    Sep 2009
    NE Ohio
    Quote Originally Posted by jansen View Post
    Thats pretty much what I was thinking. But that carrier will bolt into my 10 bolt?
    Sep 2011
    Yes, you may have to change the carrier bearings but the actual carriers themselves are the same.
    Sep 2009
    NE Ohio
    cool thanx. I will look into that.
