Page 2 of 19 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 183
Thread: 6.0 into 98 OBS
  1. #11
    Aug 2011
    Mabank, Texas
    Yessir, as stated earlier, it is a 65e, according to your vin. For sure. Sorry it took me so long to get back, hectic day at work yesterday.
    2002 Chevy Silverado 2500 HD. CAI, 4.10's, 35x12.50 r17 Kumho Road Venture M/T's. Nelson Tuned.
    2002 Z28 Camaro- Small budget cam build. Full bolt on, Custom grind Comp Cam, LS6 intake, 4000 CircleD stall, Nelson Tuned.
    2008 Dodge 2500- H&S MiniMax, CAI, DPF delete, EGR delete, AirDog fuel system.
  2. #12
    Sep 2009
    NE Ohio
    Quote Originally Posted by myzterray View Post
    i just ordered 2 15" fans from ebay..came with the temp sensor and relay for $50. i would suggest 96+ radiator. the wiring was the hardest part for me. somewhere in my swap i found wiring diagrams. also if you get the pin out for the obs pcm you can trace the wires back from there. http://www.lt1swap.com <--wiring diagrams ive spent hours on this site!
    Been on there numerous times and have taken away so much info. I am a 12 volt installer. so its easy for me to handle the wiring. Its just WHAT wires I need to use.
    Quote Originally Posted by bt02chevy View Post
    Thank You Sir.
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
  3. #13
    Mar 2012
    i did an install in a 94 two door tahoe, i had my harness builder put in the factory electric fan plugs/harness/relays, which can be controlled through the 0411 pcm, i bought some 98-02 camaro fans off summit racing for about 130 bucks i want to say, it was plug and play, also if your modding your own harness i believe nelson sells a factory fan harness that plugs right into the red/blue connectors..
  4. #14
    Aug 2011
    Mabank, Texas
    You're very welcome.
  5. #15
    Sep 2009
    NE Ohio
    Its finally out. The trans is the only thing I need out. Not really in a hurry though. Unless I can find someone with a 2wd 4L65E wanting to trade for an AWD 4L65E.
  6. #16
    Sep 2012
    Quakertown, Pa.
    Looking good. Keep the pics coming and keep up the good work.
    John
  7. #17
    Sep 2009
    NE Ohio
    Finally had a chance to get the trans out of the Denali. I was robbed. The VIN & RPO code said it had a 4L65E. Turns out they were both wrong.
    Since my truck has a 4L60E, I will be keeping it in the truck till I break it and use this as a spare. I need to get rid of the transfer case right now. I have no use for it.
    We will be pulling the rear end once the Denali gets scrapped and I will do a swap for the beefier rear end and at the same time I will use rotors from a 98 C2500 so I can have 6 lugs up front as well.
  8. #18
    Mar 2013
    Long Beach California
    just a thought.... as far as ive read, arent the 65e's the same as a 60e but with stronger internals? is it possible that GM just kept the same casing, didnt change the "4L60E" on the side to "4L65E", and just put different guts in it? then change the RPO code to show what it is? or did they actually change the casting numbers as well? as i stated, i have no idea what they did. just food for thought. if that IS the case, then you might actually have a 65.... someone who knows trannys should be able to confirm or throw my thought out the window.
  9. #19
    Sep 2012
    Quakertown, Pa.
    Not sure on that one but it does stand to reason that it may have the beefier internals while being housed in the 4L60E housing. Many 4L60E trannies are rebuilt with the beefier internals for engines with higher output.
    John
  10. #20
    Sep 2009
    NE Ohio
    Well if that is the case then I will still hold off on swapping it in till I break mine. I will do the vette servo and a couple of other things to mine as mine shifts great.
    I don't feel like tearing in to mine and the "65E" to get the tail shaft out of mine to convert the "65E" to 2WD right now. The motor may get a cam before it goes in so other than that is all stock. Mine should hold up unless I take it to the track to go play.
