Seeing some good progress on this conversion by staying very busy on this 3 day weekend. I started the weekend by deciding to tackle the conversion of the wiring harness. After a phone call to Chevy-Art, he convinced me that the wire complication was pretty much in my head and it's really a lot easier than one would think. I followed the guide on LT1swap.com, using the 04' harness guide. Mine is an 05' Tahoe harness and I found no differences between the two. Very easy task, but requires some attention to detail. I followed Art's advice and laid the harness out on a flat open surface and removed all the tape. Everywhere the harness splits or turns, I put a ziptie there to help maintain the factory shape of the harness. After ziptied, start pulling pins from the PCM following the guide.
These are all the wires and plugs that ended up being removed. I think that I will hold on to these until the motor is in place and wired. This is in case I need to lengthen anything.
Question: I cannot figure out what these 2 plugs are. The wiring removal guide ended up having me remove 3 out of the 4 wires that run to this plug. The only wire left to both plugs are a pink power wire. Does anyone know what these are?
Engine Compartment: My engine bay was in really bad shape as far as filth goes. the frame had no more paint on it and everything was covered in 19 years of dirt, oil, and grease. Since I am putting all this effort into giving my truck a new start in life, might as well throw in the kitchen sink too.
Here is nasty bay before:
And here is what it looks like after 10 hours of scrubbing with a tiny wire brush, some brillo pads, and a bucket of Dawn and Thinner and then painting.
Thanks for looking so far.
