Results 1 to 10 of 11
Thread: What cam for a Suburban?
    May 2003
    Idabel, OK
    Question What cam for a Suburban?
    If it wasn't so easy to change cams on a LS motor, I likely wouldn't even consider this.
    My goals..
    1. More Power (obviously)
    2. Stock or better MPG
    3. Stock drivability
    4. Plenty low end torque and grunt
    My considerations were LS6 or TR 220/220 - 114
    Whats your thoughts guys?
    99 C5 cam/boltons 400rwhp
    10 Sierra CC 6.2
    03 Suburban 5.3
    Dec 2011
    212/218
    May 2003
    Idabel, OK
    Are you speaking of this cam --> comp 54-424-11 aka XR265HR?
    10 Sierra CC 6.2
    03 Suburban 5.3
    Apr 2006
    Bellevue, Nebraska
    For a pig like a suburban that's the one I'd go with. Or the 455-11.
    Arizona/Utah
    Quote Originally Posted by Cccrst2008 View Post
    212/218
    +1
    Jun 2010
    Not to hijack this thread, but I have the same needs for my suburban, only mine is an '07 with the variable displacement, cylinder shut off bull crap. Will those cams work if I have the variable crap tuned off or do I need a whole different setup? I need more torque and midrange power for towing and know that at this point I need a cam to fix it but not sure what will work.
    2007 Chevrolet Suburban 1500 4x4
    LT2, 5.3l, needs some work **SOLD**
    2010 Chevrolet Suburban 2500 4x4 all blacked out
    6.0l, 6 spd auto, 3.73
    20" black Rockstars, Nitto 33s, leveling kit, Airraid might need a tune
    http://www.integrity-building-remodeling-tx.com/
    Apr 2006
    Bellevue, Nebraska
    You'll need a DOD replacement kit (lifters, valley cover, springs and pushrods) if I'm not mistaken. Can't just tune it out. Or one of the few DOD compatible cam kits.
    Oct 2012
    http://www.vincihiperformance.com/ca...s%20truck.html
    Check these guys out for tq cams.
    Jun 2010
    Quote Originally Posted by okieraptor View Post
    I found a couple that would work for me but do these cams need a DOD delete? Will they run AT ALL without tuning (I know that it will need to be tuned to run at optimal performance)?
    Arizona/Utah
    You should delete the DOD. It is useless. It will run with out tuning, but it won't run well. You should defiantly get a tune ASAP if not at the time of the swap.
