Results 1 to 10 of 30
Thread: 408.Luke Garage Sale, leftover parts from Racetruck
    Houston
    Ok Guys i still have a ton of stuff leftover from my build and its got to go cus i need a megasauirt unit. Everything is OBO so if you are interested PM me an offer. I DONT ANSWER "whats your lowest doller" PM's AND YOU WILL BE IGNORED. Make me an offer, worst that can happen is i say no. Also if yall want more pics let me know, i was limited to 25...
    First up Nissan Titan Wheel $200 one center cap is missing but i will look for it at the shop. Also they are painted Chadmod green but will try to clean them up (if they will fit in the blasting box) I never ran the truck on these, they were for my AWD setup that never ran
    7.400" 3/8" pushrods. $100 These have a few hrs of run time on them. Switched cams before shoot out and needed a shorter pushrod. Warning These dont fit in all motors.
    Nitrous Bottle Bracket with adjustable angle $120
    http://www.nitrousoutlet.com/catalog...9&product=3461
    25mm 5x4.75 wheel spacers 14mm studs $100
    http://www.summitracing.com/parts/EIB-904250252/
    5.3/4.8 Flat Tops (press pin) $50 these are out of a 04 4.8L anyone looking for a bit more compression out of their 5.3 these are perfect just sway them to your 5.3 rods
    14 Bolt 9.5" ring gear set w/ rebuild kit. $300.00 all unused parts. Gears are motive and the rebuild kit is missing some shims and pinion seal but all the bearings are there. Might be willing to separate this.
    http://www.summitracing.com/parts/RAT-329K/
    http://www.summitracing.com/parts/MGR-GM9-5-410/
    Synapse Synchronic Blow Off Valve $100
    Kennedy Diesel Lift Pump (no harnesses) $100 Supply's about 3psi great for a daily driver, was on my lly for a few thousand miles. You can put two of these together for my pressure
    http://www.kennedydiesel.com/categor...bCategory2=126
    Evap Check Valve and exhaust weld in nipple, great for any catch can setup $15
    http://www.summitracing.com/parts/MOR-97800/
    http://www.summitracing.com/parts/MOR-97810/
    Autometer GS Pyrometer Gauge 0-2000egt's with a new temp probe $150
    Autometer Phantom II Fuel PSI gauge 0-100 (new) $180
    http://www.summitracing.com/parts/ATM-7563/
    04.5 Duramax Tow Mirrors. $400 These are the ones that you can extend from inside the truck and will work on 01-07 trucks but 01-02 will need to change connectors to work. One does have a few scratches on the back and a really light scratch on the mirror. They have the turn signals in them too
    Stand Alone Fuel cell for a nitrous setup $100 has foam so no sloshing
    Allison 5 Speed Shift Kit (01-05) $200
    Transgo Allison Converter Clutch pressure reducer $30
    http://www.summitracing.com/parts/TRG-A1-LU-BST-04
    Luke how about you make me a sweet catch can from that check valve and I'll buy that.
    Or just tell Jon to mass produce them.
    Houston
    Shoot, even i dont have a DBRods catch can
    Mar 2011
    Hamilton, Ontario
    i hate to say it but what size are those god aweful colour rims?
    Limited edition only
    Quote Originally Posted by 408.Luke View Post
    Figured you would have one.
    I really am curious how much he charges for one.
    Quote Originally Posted by 89sierra View Post
    Those wherls are Titan 18's.
    S.A. Texas
    how much for the pallets, They look really good. PM me a price on the Fittings, just shoot me an idea on them.
    Feb 2011
    Sevierville, TN
    Are the Titan wheels 17" or 18"?
    Matt
    Thanks to all American soldiers for their service and sacrifices.
    The Titan wheels are 18's
    Houston
    Bump
