Results 1 to 7 of 7
Thread: how low can i go with a 4wd NNBS?
    just orderd the kit, its an Eibach pro truck
    , they say its a 2/4 with the rear block removed so were gona see if thats real or not
    I was wondring how low can i go with a 4wd GMT900 ??
    I also need new shocks the stockers are bleading like shit, i think they are out of oil
    so what shocks should i get? the bilstein 5100s if 2" lower is all i can go or get the belltech that has another 2 or 1 drop?
    Arizona/Utah
    I believe I saw a 4/8 drop on a 4x4 nnbs truck.
    Drop arms and flip kit are options to get more drop.
    Jun 2009
    Youngsville, LA
    I have seen a 4/7 on a 4x4 nnbs. Also if those shackles are two inch then you will only get a 2/3. The block is just over an inch tall.
    Jun 2009
    Washington DC
    Ive got the same drop as this kit. 2" drop coils in front, 2-3" drop shackles in back. You WILL NOT get a full 4" out of that rear setup as it is tho
    Jun 2009
    Youngsville, LA
    On mine I did DJM 2"shackles, removed the block and used Belltech struts. Ended up at a 2/3, which I think I like the slight rake.
    Jun 2009
    Youngsville, LA
    2/3 Picture. On factory plasti-chrome 20's.
    2012-04-21_12-10-01_249 (2) by texas_bred83, on Flickr
    2011 Chevy crew cab 5.3
    2013 Chevy crew cab 5.3
    Quote Originally Posted by texasbred View Post
    i like the look
    just got the Eibach kit on mondaym but the motot spun a bering on 5-6-7-8 con-rods and im looking at an ly6 wish me luck
