Appreciating the help! I am swapn 5.3 ls into 89 c1500 and have located the 94 gauge cluster and whatever wiring I will need from that truck. Do I need the DRAC/VSSB to make cruise control operational or will I be able to use the ls ecm? I assume the tach can run off the ls ecm?
The ecm can be tuned to put out the right signal for the tach, I'm not sure bout the cruze controll still figuring that one out too.
- You may not post replies
- You may not edit your posts
