Top covers
Ive never seen this before. Pretty cool. How do you cut and bend the acrylic?
 Member
						Member
						Top covers
Building a 86 Silverado 2wd sbrc, LS1 and 4L60E. Magnacharger soon to follow
HIS: 01 GMC Sierra 1500 H.D. 4X4 crew cab, loaded, 6" RCD, 3" body, 14X36" TSL Swampers, 16.5X12 MT classic 2`s, cowl hood, hypertech
HERS: 01 GMC Yukon, loaded, Denali front clip, 22" Giovannas, 2/4 drop, cowl hood, 2 baby seats
Interesting setup.
Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
EL JEFE
ROUGHNECK
 Member
						Member
						Anybody know how to make these? Will factory covers work with a magnacharger?
 Member
						Member
						Hello? .... Anyone ever worked with this stuff before. We need to figure these out. Much cheaper than the factory ones and we can add our personal touck with paint, vinyl or both. Ive got a plotter we use for tint graphics so if I can make the clear covers I can add just about anything to them. LS1 emblems, Corvette crossflags, Nelson Performance, LS1truck.com...Anything. The vinyl/paint would be on the bottom side so it would look cool and last. I just need to figure out how to make the clear covers. Thanks, Ryan
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						I believe you can bend acrylic with a heat gun. Go to home depot and buy a test piece and give it a try.
 Member
						Member
						<div class='quotetop'>QUOTE(RedHeartbeat @ Mar 23 2006, 08:37 PM) [snapback]47995[/snapback]</div>I don't think his were bent. Will exhaust heat melt the acrylic?I believe you can bend acrylic with a heat gun. Go to home depot and buy a test piece and give it a try.
2002 white Silverado ext cab. Taillights filled, roll pan w/93 Cad lights horizontally placed, tailgate handle inside, Gaylord tonneau, bed slide & bed rug, all trim removed, Escalade door handles, 18" Enkei & Falcons, Speed grill. Grill shell, bumper pad, & valance painted white. Mirrors painted white. Many interior pcs painted black (over beige), black leather seat inserts and sun visors. 2" dropped DJM lower control arm, shackles/hangers for 4" rear drop. Engine: 5.3 , Radix w 2.8" pulley, 90 mm throttle body, Dart 225 heads, Comp Cam 581-588 224-230 on 114. ARP head bolts. KTech rod bolts. Alky Control methanol injection, Pacesetter lt's into elec cutouts then 4" polished Magnaflow SS mufflers then 4" ovalized SS pipes exiting in front of rear wheels both sides, gas tank removed and 24 gal. fuel cell where spare tire was w/Aeromotive pump, pre and post filters and pump controller & -10 SS fuel line. 160 thermostat MSD wires & Perma Cool fan, 34" radiator, Meziere elec water pump. Valve covers, alternator & brackets powdercoated white. Built 4l60e, 4.56 with Detroit Locker Trutrack. 2 Interceptor logging guages, FAST dual 02 sensor wb gauge, Cyberdyne vac/boost gauge. Truck is actually the property of a little Benji type dog. Pics of him and the truck too www.swardphotos.shutterfly.com
 Senior Member
						Senior Member
						I think you would need more than just a heat gun. I think you would need some sort of template to form them to, like a factory set of covers. I got mine from ebay for $50. That's not a lot of money when you think about how much $$$ you could make selling these covers.
[1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						You're going to need something more than a blow drier.
They vacuum form acrylic sheets to make all kinds of items. I'm just not sure what they use to heat the sheet so that it doesn't shatter.
Damn those covers add that much power. Im getting some!!!!!!! LOL
2001 GMC Sierra C3 with the 6.0! Vararam King Cobra, TB bypass, No cats with two 3 inch cut outs and thats it for the motor. FOR NOW ATLEAST!!
9.5 in the 8 mile
6000K xrtalight h.i.d kit
<div class='quotetop'>QUOTE(stec3ve @ Mar 24 2006, 11:49 PM) [snapback]48184[/snapback]</div>At 9.5 in the 8 you might want to give them a try! Gotta love those extremely helpful post.Damn those covers add that much power. Im getting some!!!!!!! LOL
The Corvette inspired Silverado is now rolling strong!
http://www.ls1truck.com/forums/lsx-t...silverado.html
