Results 1 to 10 of 11
Thread: egr removal
    Mar 2006
    pearsall texas
    what do i have to do to remove the egr on my 2000 silverado any problems if i do
    00 silverado 5.3, 2005 caddy clip,mods asp pulley,e-fans,3.73s,custom intake,jba shorties,hypertech=14.9@95
    Jan 2005
    Conway, AR
    very easy, there is a kit you will need. Go to ls1speed.com. Look under 02 ls1 because they dont list the trucks. You will need the manifold plug and the header block off plate. That should do ya, if you have a custom tune you will need to have the egr codes turned off, doesnt hurt if they are on though.
    Chris
    Mar 2006
    pearsall texas
    <div class='quotetop'>QUOTE(chrisj6 &#064; Mar 19 2006, 11&#58;06 PM) [snapback]47458[/snapback]</div>
    Chris
    can i get the intake plug at a local dealer
    what does removing the egr do with performance? or just in general?
    Jan 2005
    Conway, AR
    yeah i think the dealer does have a similar kit.
    It doesnt do anything to performance, its just there to help keep down emissions.
    Chris
    Jan 2006
    <div class='quotetop'>QUOTE(duckysbht &#064; Mar 20 2006, 09&#58;11 AM) [snapback]47487[/snapback]</div>
    The egr recirculates innert gasses from your exhaust back into the combustion chamber. These gasses do not burn because they don&#39;t contain any oxygen, they help to keep comb. chamb. temps. down in turn helping with emissions. Although I think most egr valves are closed at WOT, deleteing it can&#39;t hurt performance as long as you are using good fuel.
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60&#39;] &#39;98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes &#39;98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,&#33;EGR,&#33;cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73&#39;s w/Auburn posi; Eclipse CD, Rockford 6 1/2&#39;s, Memphis 12&#39;s, Punch 200 ix, Punch 500x
    Dec 2003
    They also help dirty up the inside of the intake manifold with the carbon. The carbon sticks to any oil residue caused by the pcv valve. My 01 manifold was very filthy&#33;&#33;
    2003 Arrival Blue Silverado SS.....I just can&#39;t leave &#036;hit alone.
    Jun 2005
    Cumming, GA
    Sorry to dig up a dinosaur here, but as I recall, the 2002 Silverado does not have an EGR valve, is that correct?
    2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
    Sep 2006
    Coon Rapids, MN
    <div class='quotetop'>QUOTE(BlenderWizard &#064; Jan 22 2007, 08&#58;10 PM) [snapback]80813[/snapback]</div>
    nope no egr on my 02 so i tink u r right
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
    Jan 2005
    Conway, AR
    2002 + did away with this sensor, you are correct.
