I have a 95 sierra 4x4 regular cab stepside 305tbi and 4l60e that I want to put a 5.3 in. First thing is I want to keep the factory manifolds and somehow modify or make a y pipe to tie it all together. Anyone have any pics to give me some ideas of what I can do for a y pipe. The next thing is the fuel lines. I have what appears is a feed and return line it is steel with crimped hose on it from the factory. I tried to compare them to newer trucks with the vortec and came up with the same part numbers. Has anyone used the originals. I know I need a new fuel pump so that is no problem. Next thing I hear is mixed views on my 95 trans. I hear from some it will work fine and other saying the solenoids are different and wont work right. Anyone have any clue or has used the original. Last is I will be doing my own harness. I am not scared I was a GM tech for a few years and know my way around the diagrams and where they go. Thanks guys for any help you may give.
Josh ----- 95 Z71 ecss -6.0 swap finished 10k miles ago, nelson tuned, built tranny, 2800 converter, 4.56s truetrac
